3 inch leveling kit install
just installed my new 3 inch leveling kit last nite i measured from the ground to the fender the back is a 1/2 inch lower i want to ethier find a 3 inch block to replace the stock 2 incher or find a 1 inch i called 4 wheel parts and they got nothing so hope you guys can help thanks .
You may wanna look into a shim kit. You can put 4 shims with the block to get an extra inch.
I know that Autospring carries a 3" block but its a bit pricey. I'm sure Fabtech or another manufacturer would carry 3" blocks.
Stackin blocks IS a big deal. You have seen it done? That makes it ok ?
Trust me bud, its unsafe and horrible for the axle. It causes lateral movement and axle wrap/hop . All bad, why risk it ? Fabtech does sell a 3" block and I have seena number of em on E-bay or in the classifieds. You could also get a 1.5" AAL giving you some extra load carrying capacity but will sligthly stiffen up the ride. Some people say they can't feel it, and others say it makes it bad. The shim kit is another option... not a route i would go but its out there (thats personal opinion).
Any chance we could see a pic from the front ? Perhaps showing your CV angles and a pic of the Upper Control Arm angle ? ?
