steer stablizer
It's purpose is to reduce shimmy with large tires that sometimes happen when you hit bumps, holes, etc. If you have 33's or larger, it is a good investment. All I needed for installation was the stabalize and the mounting bracket you see on the right side. It was supposed to bolt to the lower control arm mounting bolt, but I didn't want to pull my suspension apart. I just bought a shorter bolt and bolted it to the existing hole in the frame.
