Stock Suspension issues
do you want to get back to stock height or lifted right now? stock-it probably has atleast lowering shackles if not lowering hanger(what the shackles mount to), another option is they might have removed the overload spring in the leaf pack along with one or both of the above.look at the back of the leaf spring and if either the shackle or the hanger look new or newish(not dirty like the frame) then they will need to be replaced to bring it back to stock height, one you replace those to lift it get some new blocks
Believe me I know about ford suckin you dry, when I got the truck it need the seatbelts and airbags replaced and reset and the idler arm was busted, I know thats alot of stuff to fiz but no way in heck should it have cost $2400...
o well, I'm gonna take it to my auto shop teacher see if he can tell whats missin'. also I found a place where I can get a 2inch fabtech block for 40$ would that help?
http://www.tascafordparts.com//index.do
just for you-
fill in your year,make,model then go to rear suspension,suspenion components,shackle
their even damn cheap
just for you-
yours looks like a stock shackle so now im really confused...
heres my stock shackle
and heres what i wanted you to take a picture of, the front of the leaf springs
http://i21.photobucket.com/albums/b2...backend013.jpg
here is what a drop hanger looks like
http://i21.photobucket.com/albums/b2...backend024.jpg
