Rear 5100 shock install?
Originally Posted by dirk upson
if they are like the yellow bilsteins it does matter. according to bilstein the boot should be down. you should be able to read bilstein without standing on your head. fox shocks have to be mounted shaft down....
Got a winner!! Shock should go boot (shaft) down. As for protection purposes, that shaft is substantially stronger and less prone to damage/dents than the body of the shock. Thus, the body goes up for protection purposes. But it also has some to do with the valving/internals as well. As for mud, gunk, and what ever else was mentioned getting on the shaft, these shocks have a scraper (most shocks do) who's sole purpose in life is to clean the shaft off as it compresses to prevent any grit or grime from damaging the seals, much less getting in the shock.
I am somewhat surprised to learn that the NBS trucks have the same mounting style at both ends of the shock?? The older trucks were not like this, thus making installation a one-way option. Those are always mounted body up. Look at any tough, off road shock...Edelbrocks, FabTech, etc...body up! And most guys don't even run any boots!
Ok to many competing answers. So i went to the horses mouth and called Bilstein. They said there is a blue Bilstein sticker on the shock and you should be able to read that when installed correctly. It should not be upside down.
Just checked mine and that would put the boot down.
Now ive got you!
Your thinking that in all the commotion did i shoot 5 or 6. Are you feeling lucky! Well are you punk?
Now run out side and check yours are in right.
Later.
Now ive got you!
Later.
Now ive got you!
Later.
Now ive got you!
Later.
Originally Posted by kaboom10
No absolutely not. My truck must be upside down.
Does No absolutely not = Im wrong/ Bilstein the designer of the shock is wrong about how they install??? hmmmmm.
Maybe yours are installed differently if there not the 5100's. Just a thought.
If you have the Bilstein 5100's designed for 0-2 inches of lift install the rears with the boot down (its what I have on my truck and that's how I installed them per Bilstein instructions) but the Bilstein 5100's designed for 4-6 inches of lift (the ones that come with the RCD kit or you can buy them separately for the Rancho kit or Superlift kit) you have to install the rears with the boot up. Problem solved, do the research and you'll find the anwsers
Hey 07fx4silver,
How is the ride compared to the old stock shocks. I see some pics of your shocks in your gallery. Does your front shock have a boot as mine did not come with one like the rear?
I see you have the 2" leveling kit also. Did you re-use them or use the 1" or 2" spring perch location on the front 5100 shock.
I'm trying to decide whether to re-use my 2" leveling kit or the 1'' or 2'' option on the shock.
Thanks.
Thanks.
Hey 07fx4silver,
Thanks.
Thanks.
The front coilover shock does not come with a boot. Ride is much more controlled and responsive over stock but get them off the pavement because this is where they really shine. It's up to you what you want to do for lift but since you have a 2" leveling kit I would ditch that and just use the shocks for your lift. I re-used my 2.5" leveling kit cause I want all the lift I can get, even if it's only half an inch more.
???? I guess yours are in wrong by your comment. Which by the way is a little confusing.
mine are upside down, no problems at all. I dont think it really matters up or down. If im correct the 5125's come with the 1/2 sleeve in them since they are generic and youll have to go to summit and get the 12mm step down. I was told the shop that did the lift should have sleeves, but i didnt want to drive back to dallas...
