Grease from idler arm
I was under my 02 F-150 today changing the oil and I noticed that there was a big glob of black grease where the idler arm connects to the steering linkage. This is a relatively new arm and has the grease zerk at this joint. I didn't have a flashlight to give things a good look, is this normal or do I have a bad part? Usually grease leaking from a ball style joint is bad, maybe the last tech to touch the truck just put in too much grease?
Assuming this is all normal I was going to grease the suspension. The new parts with zerks have only been installed for a few months, I haven't greased a suspension in decades. What type of grease should I use?
