Help!
Help!
I just bought a leveling kit 2.5" for my 2004 fX4, we've taken all of the steps in the instructions, but when you get to the step where you have to take the bolt out of the ball joint, we've been stuck. That bolt will not come out for nothing, in the instructions it says to hit with hammer and should knock loose, well that aint the case. I've takin the truck apart and put it back together the past 2 days now and have made no progress, i cant get that bolt out of the ball joint? any suggestions? i think we've tried just about everything, tommoro i am going up to the shop to borrow a ball joint press, if this doesnt work idk what im goin to do .. any help appreciated
Thanks,
Bray
Thanks,
Bray
Ball joint trouble
I put a spacer on about a year ago before I lifted it. You have to hit that sucker HARD! I used like a three pound ball pene hammer and hit it right where it strarts to curve towards the ball joint. I think even then I had to hit it like three or four times. If your using a regular hammer you will be there all day and then probably break the hammer.
Orrrr....You could just say screw it and BUY A LIFT. You will never regret it.
Well good luck. Oh yea...When it does finally break loose, make sure you'r supporting it so it just doesnt drop. Mine almost yanked the break lines loose.
It wants to pivot outwards when it comes loose from the top ball joint. Puts alot of sress on those break lines.
This was mine witha 1.5" spacer. Watch those angles.
