Negative camber issue
I recently purchased a 2000 f-150 4.2 2wd. I believe the previous owner installed a lift which caused a negative camber in the front tires. I have been told that I need to replace the upper control arms to solve this problem but it seems to me that it would be a frustrating situation for me because I don't know what size lift is installed or what size of arm is needed to correct it. Is there an easier way to do this or at least a way to determine the lift size? Thanks in advance for any help. It is appreciated.
Originally Posted by longjohnsilver
When you took this pic, was the frontend raised off the ground??
If not, your upper control arm has maxed out it's lower travel. The lift kit has really messed up the geometry. From evidence in the photo, an alignment won't fix it. I'd put stock springs back in and see what happens.
Man, that's bad. Real bad. You can see the coilsprings are blue which indicates that they are aftermarket lift coils (Fabtech maybe?). Take a look on top and on the bottom of the coils. Do you see a spacer? I'm guessing someone may have combined lift coils and coilspspring spacers to gain more lifts. If this is the case, you will need new upper control arms to get the alignment within specs.
I wouldn't be surprised if the upper control arms aren't stealing some additional lift that the springs should be providing. What size control arms should be installed? I'd really like to get the right equiptment but at this point I'm not above fabricating the existing control arms to accomadate the lift. What do you think about that?
I dont think that will help your situation. Most companies sell lift spindles that simply bolt on. These can be combined with lift coils or a coilspring spacer to gain more lift. And, as you said, some taller lift kits combine lifed coilsprings and lift spindles. Your problem appear to be too much lift with just a spring or a spring spacer combination. The only way to correct it is with longer upper control arms. I think if you add lift spindles, you will just wind up with a taller truck with camber issues.
