Fabtech or Procomp?
I like procomp just for the fact that the procomp lift I installed went on much easier than any Fabtech lift I've put on. They are both quality kits and you will be happy with either one.
I carry both fabtech and procomp, so feel free to shoot me an email or give me a call and we can work something out.
Which part do you like more ? Stacking the rear ALUMINUM blocks ?
Or is it the huge spacer up front, to keep the factory crap.. i mean shock ?
Or is it the low hanging, weak looking front cross member ?
(I have never seen one broken tho)
And I would agree with Alon, Pro-Comp went in easier, I think due to better directions. IMO Fabtech directions look like someone wrote them who had NEVER actually done the install them self ! But, if your mechanically inclined, you can read through it to get an *idea* of what to do, then go from there.
(or were you disagreeing with me saying both are good kits ? )
When we did a 6" procomp on a chevy 2500 it seemed to go on much easier...and all the parts were there.
We are talking about 04+ FORD F150s here though.
My Pro Comp stage 1 lift has been more than adequate. Sure, the front cross member lacks the bling that the Fabtech kit has (and especially the Rize kit ) but I promise that peice is more than up to the job in terms of strength. I am still unclear as to the differences in shock and coil-spring mounts between the two kits... my Pro Comp has a large coil-spring spacer up top, and an extended shock that passes through everything to the original shock mount at the top (basically, it is like a 6" leveling kit with longer shocks).
In terms of rear lift, I agree that the Fabtech's single block is superior to the Pro Comp's stacked blocks... but even then I have had zero issues with mine. Either kit will ride well, and either kit will net 6" of lift (my Pro Comp lifted truck sat next to a 6" Fabtech lifted truck and it seemed like my truck was about 1" taller, but it could have been tire pressure, or any number of things). Both kits are great buys for the money, and will last a long time. Either kit can be upgraded to coil-overs, and they are interchangeable between the two brands (you can run Dirt-logics on a Pro Comp lift if you want).
Either way, you will be happy.
Fabtech is still better !!
I've installed both so here's your primary differences in the two. Fabtech comes with a differential drop brace, rear driveshaft spacer, a 5" block and new shocks up front. Procomp uses an aluminum block to be double stacked and a spacer for the front coilover. If you get the stage II then the spacer is irrelevant. As far as the front crossmember they're both the same durability they just look different.
On a side note how come whenever someone mentions they want a fabtech or procomp then rize or cst gets brought up?
