Torsion bar crankup vs levelling kit
stiffer means that bumps will hit harder, but the truck won't feel so spongy over them. the truck won't bounce as much when you apply pressure to the body. you'll be ok. Like was stated earlier, a leveling kit accomplishes the same exact thing, only it adds unnecessary hardware, and promotes excessive cranking of the bars. just mark the threads with spray paint before cranking, so you'll know exactly how they were adjusted, if you decide to go back down.
i would like to touch on the part about cranking the t-bars with out lifting the front end. yes you can do this, but i do not think this is the best way. by lifting it you are taking the stress off those bolts as your turn them (lessing(sp*?) the pressure on them), which in turn will decrease chances of breaking a rusty bolt. also, if you do crank them while it is lifted set the truck down and drive it so it can "settle" and measure again so you know you have the right height.
Ive cranked mine all the way up for about a year now. I havent noticed any "bad" wear. My ball joints are looking good. The angle on the CV shaft is less than desired but it doesnt bind up or anything.
I think he is just trying to say that if you lift the front end, it will be easier to turn the bolts. That is what I did on my '02 about 5 years ago, did 3 full turns got about 1.5" of lift. Then went and got an alignment. The ride did get a little stiffer but not much. Here is a pic of the bolt....
thanks for clearing that up. 4.2trimble sorry about the confusion i see how you got the wrong idea. what i meant to say was you should jack up your front end when tightening the torsion bars so the suspension is not already loaded and this was the bolts will turn easier. hope that helps
The first time i cranked my torsion bars i lifted it off the ground and it still look all my might to turn the bolts.
the second time i did it (when i put my body lift on) i had sprayed them with PB Blaster for 2 weeks and i could turn them with my 1/2" Cresent Wrench.
I got 2.2" of lift out of mine if not a tad bit more.
With an impact wrench you will have hard time knowing if you are turning both bolts the same amount and or how much you have turned them.
As mentioned, shoot them with PBlaster the day before, and use a socket or wrench, taking note of how many turns, do the same to the other side.
I didn't raise my front end off the ground nor even use PBlaster...and they were tough to turn at first, but they will turn.
