Torsion bar crankup vs levelling kit
Just wondering I am in the process of putting a 3" bodylift on my 02 screw and was wondering if i could get the pros and cons of cranking up your torsion bars vs using a levelling kit ive looked at a bunch of kits and they all say a kit is gonna change your handeling negatively so why not just crank up the torsion bars?
First, you only have torsion bars if you are 4x4, but i'm sure you knew that. Second if you do have torsion bars, a leveling kit is just new torsion bars which the generally consensus is that these will cause premature wear on your suspension parts. So yeah just crank up your stock TBs if you want the truck level. Welcome to the site
Just Crank you stock torsion keys to make the truck sit level, I have had mine cranked 3/4's of the way up for about a year and have had nothing bad to say about doing it this way!
DONT BUY AFTERMARKET TORSION KEYS!!!! AKA "LEVELING KITS"
Pardon my "newbieness"... lol
Is there pics or directions on how to crank the torsion bars? I've only glanced at mine the other day and they look pretty rusty, so i assume spraying them with PB Blaster and letting them soak for a few hrs would help. Do you have to jack up the front end to do this ? Tools?
Thanks for the help!
i've read that you have to jack up the front end to do so, however, i did not. all you will need is an 18mm socket, 1/2'' drive, and a 1/2'' breaker bar. i didn't even spray mine, and i still managed to get them to turn. it took a lot of effort though. i would recommend spraying them a day or two before. turn one side three equal turns, then the other. repeat this a couple of times. if you crank them all the way, the passenger side will be higher than the driver's, due to the gas tank, and the front will sit ~1'' higher than the rear. Play w/ them until the truck sits as you like it, then get an alignment. Everytime you fool w/ these, you'll need an alignment, so keep that in mind. Also, the ride will stiffen as well, depending on how high you crank them.
