Noob ? : How to measure my lift
Agreed. Fabtech only makes a 6" kit for the 04+ NBS F150. The Dirt Logics could be cranked up for another two inches or so but you'd be able to tell just by looking at your CV axles. If they aren't straight, than they are probably cranked. Actually I just looked at your pictures and you do not have Dirt Logics. Those are the standard Fabtech shocks with stock coils. It's a 6" lift, no cranking, no spacer, etc.
Thats really pretty straight imho. My CV shafts are at pretty extreme angles. do to the torsion bar crank (99). You should be fine with them like that!
Im saying 99% sure that you have the basic 6" Fabtech. If you want the total amount of lift then you have to figure out what the stock tire size is. The subtract that from the 35 that you are now running then divide that in half. then add that to the 6" that the lift gave you.
For example. 6" lift
stock tire size 32
new tire size 35
which equals 3"
divide that 3" = 1.5
add that 1.5 to the 6"
7.5" is how much your total lift is including heigth gained my tires.
stock tire size 32
new tire size 35
which equals 3"
