Show off your lift.
#106
jditta: thanks. the lift rides fine no problems. my lift actually equals to 5 1/2 inches instead of the regular 4 it says. also i believe ATOMs rancho lift did as well. and as for the block im not sure i dont remember. my opinon if you have the funds do a 6 in lift with coilovers, unless all you want is the 4. cause im looking to find a way to go up more now and im not really wanting a body lift.
#107
yeah i did get a little more than 5 inches outta my rancho. if you wanna go higher ColonelBlue throw a spacer up front or some 6" bilsteins. WowakFX4 has a rancho and a spacer and his angles aint real bad. i thought maybe if had something to do with xlt vs fx4's but either way they get the same shocks so thats not a factor. the one thing i dont like about rancho is how damn much they want for a skidplate, 375 bucks for a skid plate!!
#108
I went and did some re-measuring last night and suprisingly enough I was wrong. I was measuring the wrong rear block, and it is 5" (I was measuring the bracket at the end of the leaf spring).
Also, even though there was a 1.5" drop off of parallel on the LCA which corosponded with the Bottom of the coil spring being 1.5" above where the outer and inner tubes of the shock were, my fenders are at exactly at 45".
So... I was totaly out to lunch on my measurements and assumptions.
It is a straight 6" Fabtech lift.
Thanks for helping me out
#111
Specs:
8" Rize
3" PA Body Lift
Bilstein 5100 up front 5150 in the rear
Rize rear block and 2" add a leaf in Rear, but will be switching to a deaver pack
4.88 Yukon Gears front and rear
22" XD Hoss
41x14.5x22 Iroks
AMP Research running boards
8" Rize
3" PA Body Lift
22" XD Hoss
41x14.5x22 Iroks
#113
looks great, but how often do you have to replace ball joints/tie rods/etc.? Does it ever go off road?
#114
Other then that the kit has only been on for a few months I've moderately offroaded it a couple of times and it performs for what it is... "A truck with a lift kit" I'm sure its just a matter of time before something snaps???
#115
08 Black Screw
My Truck with 6" lift & 35's. Here is a pic of my new 12" Rize lift going on, putting on 20X10 XD Diesels, & 40X15.50 Mud Grapplers
[IMG][url]http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=71117404&a lbumID=2302883&imageID=33631374[/IMG]
[IMG][url]http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=71117404&a lbumID=1576089&imageID=24017856[/IMG]
#116
The truck had 80,000 k on it when I put the lift on, I replaced the upper controls, lower ball joints, tie rod ends and sway bar end links with new factory pieces (also installed zirk fittings into all them) So I let you know when they fail?. Not too concerned though!, I do all the work myself and ball joints are a breeze.....
#118
#120
