steering shaft/column
I know once you install a body lift you have to use a steering linkage spacer.
I had to install a new heater core and ever sence then i cant get my
steering column to bolt back in place.
could the steering shaft lock in place and not let me install my steering
column ?
i forced it to go into place but then i cant steer. It will get real
stiff and make it hard to turn the steering wheel.
So is my linkage from column to steering box messed up ?
i tryed to move my steering shaft by hand and i cant push it in or out when
its not connected...
I have been driving with the steering column only bolted up with 2 bolts
for a long time and im tired of the column moving ...
98 f150 4x4 3"body 5.4swaped
thanks for the help
column ?
thanks for the help
