rear leaf spring replacement
I have the Explorer Pro Comp Add-A-Leaf. I works just fine. Not much can go wrong with it if installed properly. Just shop it around. You'll find them for different prices.
But I think what you have in mind is a Deaver Suspension.
i already have the skyjacker aal but im not really that satisfied with it. the ride is a little rougher and the squeaks when i go over bumps slowly. i was thinking of completely replacing the stock leafs for something new and not using a block either
To my knowledge deaver does not make a stock replacement, just the 4" leaf packs. Your going to be looking at custom for them to make a stock replacement. I have the deavers, but in a 6" leaf pack with a 4" block. You will still get some sqeek over time, ride is smoother but you lose some payload/towing ability because they are so soft. Paired with my bilstein 5125's the ride is excellent. Next spring i look forward to trying them out with some custom valved piggyback kings.
