who is using axle degree shims???
hi all, im trying to find out who here is using axle degree shims... i ordered some and recieved a set that is only drilled for a single bolt hole..... now, i know that our trucks have 2 in the spring packs. so, should i just drill the correct holes, or is there a kit that is made just for our needs?
im trying to get my driveshaft pushed forward just a little, since im using a 5" rear block, and 1.5" lift shackles....
Thanks !!!
Thanks !!!
