I am officially baffled!!!!
Changed all ball joints, tie rods ends are still good, haven't changed sway bar links yet but they are not broke, changed 1 coil spring, relubed the lower strut mounts, checked intake and still have a popping noise when hitting bumps and dips what the heck could it be? While driving it sounds like it's coming from the driverside front it started doping this a few months after the lift was put on. I did however get rid of some other noises but i'm still not satisfied. Anybody have any input on this. It is driving me crazy. I'm to the point of trading this truck off. Maybe I need to recruit someone to hang on under neath my truck while I drive it so the can have a look see. Oh and by the way this truck only has 25k miles on it.
i had the same issue with popping. turns out it was the lower control arm bolts. the pocket on the cross member is just a hair bigger than it needs to be for the lower control arm. i had it in for an alignment a month ago and had the guys torque the mess out of them. he put around 260 ft/lbs on em. noise is gone.
Haven't checked actual brackets for lift, I went back through my instructions for the lift and there are no torque specs anywhere for anything other than ball joints and strut mounting bolts ford says 351lbs and auto springs said like 225 that is quite a difference. My torque wrench only goes too 250... Anyway going to check all that, and also thought about pulling the sway bar completely loose and driving it down the road to see if that is the culprit. What are the torque spec for the A-arms?
Surprise, Surprise... It was the driver side sway bar link. It is not broke but is completely shot, will have some tomorrow. Meanwhile I'm still checking everything underneath just ran out of daylight. However, I did drive it with sway bar totally unhooked and the noise was gone. There was about a 1/8" in and out play on the bottom mounting joint.
Appreciate the help guys!!!!!!!!
Now does anyone know where to get extended brake lines for our trucks? Haven't found anything yet.
