Offset Autospring
Offset Autospring
Hey guys I supposedly have the "offset" Autospring but I have noticed my upper control arm still hits/rubs the coil when the tires are off the ground. I dont think it ever happens while the tires are on the ground though.
My understanding was the offset kit was supposed to prevent this. Did I maybe get one of the last kits before the offset kit or is what I am seeing normal?
there is only one way to install them, based on the bolt pattern on the top. im wondering if your AS changed the orientation on the coil...... or are the coils bolts lined up with the spacers bolts? you might have one that isnt offset, but i think that what your seeing is completely normal..... it would be almost impossible for anyone to say that your UCA "will not hit the coil" when your suspension isnt loaded.
Yeah i have same issue as you.
it was not too bad..
i have a offset AS 1.5". it hits coil springs when dropping the tires.
i noticed this ONLY happens when the steering is turning on the corner on uneven road.
I didnt notice that much when its driving straight ( hit pothole, beach etc.
YOMAN!
YOMAN!
YOMAN!
YOMAN!
