Bump Stop Question
Bump Stop Question
I have a 2000 4x4 with a fabtech 6" lift on it. I was looking at it today and there is only about an inch to inch and half of travel before the bump stop hits. Is this normal or should i crank up the torsion bars a little to give it some more travel. The truck is sitting level now so im worried if i crank it up it wont sit level. Here is a pic of it.
FYI, if there is 1.5" of compression at the bumpstop, there is probably 3-4 inches of compression at the wheel, atleast. Due to the placement of the bumpstop in the inner part of the control arm.
You could also probably cut the bumpstop down a little, for more compression if there is room in the wheel wells and nothing binds.
