is this a way i can level my truck?
He has a 2wd which has no torsion bars. thus nothing to crank,
The torsion bar crank is perfectly safe i have had it done for close to a year with no problems. But this is only for the 97-03 F150 4x4's
If you want just 1 inch of lift in the front, get the daystar 1inch coil spring spacers. IMO, don't go with any higher coil spacer than 1 inch. If you want more lift, like 3-3.5 inches, get lift spindles from fabtech or doetsch. With either of these lift methods, you do not need to get different length shocks but would be a good time to upgrade to ranchos or bilsteins.
You can lift the front of a 97-03 4x2 up to two inches using Daystar coilspring spacers. If you go any higher you will need new upper control arms to get the alignment within specs. You may need to add adjustable camber bolts with the Daystar spacers also. The are about $40 at most parts stores.
