Question about AS leveling kit
I just installed my 2 inch AS last night. I noticed the upper control arm is at a pretty decent angle now is that normal?
I will post some pics of the truck tomorrow.
By the way once you get one side figured out the other one is pretty simple.
I had a problem with the upper ball joint spinning, if you put a jack under the lower control arm and jack it up a little it puts some pressure on it so you can tighten the nut. Same with the nut to get the sway bar disconnected.
My hat goes off to TXST8tj for the great write up. It helped out a lot
Well i looked at them again and it isn't bad. When i was wondering about them it was while the truck was in the air with no load. Its all good now, I think my truck rides better now for some reason and looks sweet. Ford said the alignment was slightly toed in but not to bad. 40 dollars for those of you who are wondering. total price was
70- kit
40- alignment
40- tools- 20 dollar wrench that wasn't need so will be returned. that giant bolt didn't really spin it could have been held with a channel locks.
the 30mm axle socket 10 dollars had to be a deep because the short i bought wasn't long enough. save your self the drive and spend 1 more dollar on the deep. 18" breaker bar was enough to break it loose.
130 was the damage to the wallet.
I will post pics this weekend.
70- kit
40- alignment
