Super Newbie...just got a leveling kit...good or bad?
so im brand spanking new to the site....need you guys wisdom and experience.....i have a 2005 supercrew 4x4 f150.....wife just got me a 3" leveling kit...it says fat bobs garage 3" powdercoated steel leveling kit for a ford f150 2004-2008.....is the 3" the right size as i have read on the forums about angles and stuff.....i would like to put 33's or maybe 35"s with my stock rims.....will all this work...worried that the front end will be higher than the rear....any advice or info would be great guys...
The tires will not "fall off" unless your ball joints come apart. If you look at some of the pictures of installs they will show you ball joint angles. I put a 2" on my truck because of the angle the 2.5" and 3" put on the joints. There are guys on here that have 2.5 and 3" that will tell you that it is okay. Then there are some that will tell you otherwise. Anything over 2" really puts the joints on a major angle and can surely create some major issues. This just my two cents take it for what you will...... Good luck at whatever you do.....
The problem is anytime you increase the angle of the ball joints, you increase wear (meaning they will wear out faster). On top of this the life span on ball joints on the 97-08 F-150's is pretty short to begin with. Mine were replaced at about 60,000 miles and my truck is never off roaded or abused.
