bilstein 5100's??
bilstein 5100's??
My local shop put these on my 05 f150 but didnt adjust them because they said they you cant adjust shocks. The more and more im reading on this site says that you can put them on a 2 in lift setting? what should i do i want the extra 2 in....i have a 6in procomp lift on it also..thanks
the part number you're looking for is BE5-C298-H0...or H1.
it should be easily seen on a label close to the bottom of the shock where it bolts to the lower control arm. my 5100's came pre-configured for the 2" position out of the box, but there are two more grooves in the shock that you can swap the rings to.
