Leveler, Autospring, Shocks......school a newbie/probie/novice/greenie
I usually go the other direction when it comes to mods so lifting/leveling is relatively a new thing for me. I understand the leveling kit and just want to know whats the best one out there....from the posts I've read the Autospring set up sounds like the way to go but exactly what is it?
I have seen a post or two about changing out the shocks to Bilsteins. Does this need any other part besides the shocks?
What are my options as far as leveling my my 05 XLT SCab? My mind is a blank slate, school me. Well it's pretty much a blank slate all the time.
The Autospring leveling kit is basically a metal spacer that bolts on top of your coilover shock assembly to lift the front of the truck a couple inches. This is the least expensive way to lift the front and level the truck.
Another option is the Bilstein shocks. These feature adjustalbe spring preload so you can raise the front of the truck. This is a better option because you gain a better shock. TO install them, basically you remove your coilover shocks, take the coilsprings off and install them on the Bilstiens with the desired preload and then mount them on the truck. It takes a heavy duty coilspring compressor to remove the coilsprings.
