Leveling kit for an '07
I just got an '07 F150 Supercrew 5.4. It currently doesnt have any suspension mods but I would like to do a leveling kit or small lift to level it out and maybe add to the looks some. It is an everyday driver and I commute a little way to work so I dont want to do too much to it and want to keep the smoothe ride as much as possible. Do you all have any suggestions on what route I should take and what brand of products I should use to accomplish my goals??
Thanks ahead of time for any help you can give me.
Welcome to the site!
Is it a 4x4? If so, then Auto Spring 2" level kit, or 2.5" w/ 3" rear block. This will keep the stock ride quality. The 3" rear block would replace the stock 1 and 5/8" block to give you ~ 1.5" lift in the back. You would only want to do this if you went w/ the 2.5" level kit (and wanted to keep it levelish, maybe a little front down, but not much) - or if you wanted to "lift" it ~ 2" all around and keep some of the factory rake on the truck. You'll love the looks of it either way!
