Just Cranked the T-bars.
I might go up one size, later - Not in a hurry for that really.
Not really any problems but just a change. My ZX2's timing belt broke and ive been driving my truck 30 miles oneway to school. So with that said im not putting 285s or bigger on it for awhile. With my current setup its stiff, which it I like, but it does get alil bumpy. I did even realize mine was stiff until I rode in my bros supercrew.
So i'll leave the AAL in and take the block out....
OK I'm a newb, and little bit of a tard, so be nice....
If you have read any of my other posts you know that I've been looking for ways to get my 08XL 2WD to sit a bit more level. I'm not going to be able to use a leveling kit because I'll void my warranty. Can I gain any noticable front end stance difference by adjusting torsion bars? I know it will not be a huge difference but an inch or so might make a big difference to me.
Wow, cranking the torsion bars and adding 3" blocks made quite a difference. I'm glad I looked into this thread, because my truck has the 4" rancho lift on it and they used 3" blocks and the torsion bars havent been cranked at all. So if i ever want my truck to sit higher i could always add the aal or throw in a bigger block if i ever crank the torsion bars. I have 285/70/17's
Yea , I hear yuh - It's getting old real quick. I like it that level, maybe another inch or so. I'm going to Crank them back down and go with a 3 or 4" suspension lift. It has to be hard on the front end.
I didn't install AAL in the back, I had 4 springs back there from the factory - I replaced the factory 2" blocks with 3" blocks as well. I ony bumped it an inch in the rear.
They did had to install a Cam kit to align - Needed new shocks aswell, I bent the shafts on the Bilsteins - That was my fault
Lol, yea - I don't get to many shots of her on the outside. Running very healthy after that last Port and polish/ Denso's/Coils/Lt's Hf's - Running a better combination muffler, has all kinds of torque . I finally have a combination she likes. Peters out @ 4200 rpm, but she really likes 3600 . Probably getting a little tired @ 260,000. - Can't complain that's for sure.
Here's a couple after she came home from the frame shop - Front end was dialed in perfect - Dead nuts! The shop had the latest in laser lining equipment, that place was bad a$$. -
Thanks! Yep, I try to take of her. Cleaned out the shop and found a court and 1/2 of Amsoil trans fluid/ 1 court of Castrol Merc V and 2 courts of RP Synthetic. I pulled the Power steering line and flushed her out real good with the Amsoil and filled her up with Royal Purple.
The PS wasn't that noisy to begin with - just haven't flushed the PS yet, so - seemed like the thing to do. It doesn't make a peep now
Or drive around with a few 100lbs in the bed and make it go down a little to sit level
Looks good Jbrew! What a big difference that makes.
Thanks! - She just needs a little tunning, I gottuh get the sound right - Like this -
http://s75.photobucket.com/albums/i2...ynoTune007.flv
