Bad and EXPENSIVE news about my squeaking and shaking issue.
https://www.f150online.com/forums/19...0-vs-e150.html
Im okay, GF was a little sore but recovering
For ford parts online check out http://www.discountfordpartsaty2kford.com/
yeah I guess they are. Back when I bought this truck a little over a year ago, I replaced all the tie rods + upper/lower balljoints and I remember it being somewhere around $300 for parts. I later replaced the idler arm and later pitman arm for pretty cheap as well. I just go to the NAPA here because I know everybody there and can trust them, which I can't say for the Vatozones and discount autos around here.
What squeeks and while doing what? Over bumps, I'd say upper or lower ball joints or both, side to side, pitman or tie rods. Bounce the front end, if it keeps bouncing, shocks = crap. Considering this mechanic figures by looking at your rotors that in deed all 4 are warped at the same time, he's trying to throw one in you a bit.
replaced my inner, outter tierods, upper and lower ball joints and had the alignment the within factory specs. in 3 hours and it was the first time i had ever done it.
bet i cant do that agian.
i also only payed 250 for everything... connections from NAPA.
The guy doing the alignment charged me half price cause it was so close. lol
hmmm. thanks! my mechanic said this is a first for his shop so he couldnt give me a deffinit that it would stop squeaking. man all my freaking graduation money is going to have to go to getting my truck to stop speaking and new rotors and pads... gah. then another $500 to pay my parents back for a new computer cuz my house got struck by lightning.... i just wish when it got stuck by lightning it would have left a lightning f150 in my drive way.
ITS EASY AS LONG AS YOU MEASURE EACH SIDE FROM THE SAME PLACE ON THE FRAME TO MAKE SUR EACH SIDE IS EQUAL,THEN DO THE SAME WITH THE TIE ROD AND YOU SHOULD BE GOOD ENOUGHT TO DRIVE TO THE ALIGNMENT SHOP.AND FOR THE PITMAN ARM PUT IT BACK ON THE SAME PLACE YOU TOOK OFF.JUST USE A SHARPY TO KNOW WHERE IT CAME OFF PUT 2 MARKS ON ON EACH SIDE.(MARK THE ARM AND WHAT THE ARM COMES OFF OF,THEN PUT TO 2 ARMS TOGETHER AND REMARK THE 2nd ONE,THEN PUT BACK ON THE MATCHING LINES.) GOOD LUCK NOT HARD,MY BRO DID THE SAME **** ON A DODGE AND DODGES ARE HARDER TO WORK ON THAN FORD OR CHEVY.
