back end comes around hard??
I think I need new shocks. I bought this truck not to long ago and it had approx. 92,000 miles on it. I have noticed that when I am drivng at above 30 mph that there is a "chatter" in the rear when I hit a bump. The front seems to go over the bump fine but when the rear tires hit it, they hop. If I am turning, like on an overpass or ramp and encounter a bump, it jerks the wheel and throws the back end around like it wants to fish tail. Its not an alignment issue and the tires are good. Shocks???? back and front or just do the back first because the front "aint " cheap.
In one respect the truck is meant to handle under a load, but should still be drivable empty. Out of curiosity, is this your first truck? If you are used to other vehicles and how they ride/handle what seems normal to many of us may seem a bit much to you. In other words I may just overlook the feelings you are experiencing.
first truck??
hawk, thanks for the response, but first truck?? Come on, I am a 40 yr old male from TN, bite your tounge. This is my 6th FORD pick up and 2nd KR. What makes me notice it is that I have never had another truck do it. Its not a rough ride, the back end literally feels like it wants to fishtail on me. Again, its primarily if I am turning and hit a good bump, not going straight.
New shocks in the rear will help. There is one bump on the interstate that I hit daily that does that. I watch the pick ups in front of me to see how well they handle it. My 01 had trouble with it. When I put Rancho shocks on it did great.
Now my 08 does not take it as well as my 01 did. I put Bilsteins on expecting it to handle it perfectly. I first put Bilsteins on the rear and the hop is gone, but the front still had some chatter. Then I put Bilsteins on the front and it is much better, but there is still pull to one side. I think it is the road and there is nothing I can do. The 08 still does not take it as well as the 01 did.
No problem, just not having a good morning otherwise it probably would not have bothered me.....no worries. As far as cost I am sure someone can answer this better than me, but if you look at the form/fit factor the construction of the front shock appears to require additional fabrication, not to mention larger bushings etc.
My F-150 '97 2WhlDrv does this on certain interstates here in Kalifornia.
The Monroe shocks are about 2 or 3 years old. Front end is fine (aside from a boot that is leaking and I need to replace the A-arms I guess), no hope, smooth. Back end (empty) is very jiggly (190K miles on her). Just bought some Bilstein rears (at good discount -shockwarehouse) and will see if exchanging the Monroes out helps the back end. With full tank of gas it is definitely better so I'm sure it is basically an 'empty bed bounce'.
Leafs were changed out at about 55K so they are not bad.
Doc
Doc
