Lower ball joints
Lower ball joints
Well I took my truck to the local repair shop to get the front end aligned and they checked it out and said the alignment was fine. I asked them what about the bad wear pattern on the inside of both tires. They said maybe tire pressure or shocks. Then I remembered I had been hearing some knocking noise in the front end at lower speeds they said maybe ball joints, so they checked and sure enough both sides lower ball joints are bad. They want $407 to do the job. Is this a normal price, and how hard is it to do myself, will I need any special tools?
you can get the OEM ones from Tasca for about $40 each, or a good set of Moog for $45 each, and im sure you can rent a balljoint press tool from a local autoparts store for basically free. so i bet for less than $100 you could do it yourself!!
You are sooooo right. The alignment cost me $59.95, the repairs would have cost $747. So far my warranty has payed out about $3200. Almost 3 times what I paid for it. So it has paid for itself and then some.
Did you get a third party extended warranty? If so, what company? I need to get one, but I've heard a lot of horror stories about them.
