Hydraulic Bump Stops and Limited Straps.
Since there's a decent chance of this truck leaving the ground momentarily, I couldn't do without a set of air bump stops and limited straps for both front and rear suspension. The main purpose of a bump stop is to serve as some final suspension cushion to keep the metal parts from coming together or from traveling too far, which might in some way damage the suspension or chassis. In my case damaging my custom camburg Upper A arms.
The limiting straps keep the weight of the entire axle from hanging off the shocks, and become the most limiting factor in my suspension. In this case for instance. Related video when this happened:
http://www.youtube.com/watch?v=INB2VPOY4-8
To place them correctly I took the truck to Wicked Creations in Garden Grove, CA http://www.wicked-creations.net/ where they removed the coil overs and collapse the shock and cycled front suspension. To properly place the the front bump stops they cut and fabricated dimple plate and welded it to the Rize frame along with bump stops mounts.
At the rear they disassemble the leaf springs leaving only 1 and collapsed it up wards in order to place bump stops in its proper location. I also requested for dimple plate to be welded on chassis, just for looks. Finally after all suspension and tires were installed vehicle was raised in the air and limited straps were then installed.
Wicked creation also custom fabricated a pair of upper A arms and installed with hime joints, I also had the A arms powder coated silver and black.
Test Run after bump stops, limited straps and deavers were installed. Truck suffered a lill heart attack 4 days after this ride and is in the shop pending surgical procedures: Blown head gaskets. I hopping to get it back this week.
http://www.youtube.com/watch?v=zXtLg92KwCI
Here is the breakdown
8" Rize Industries= $3,000
Front and Rear 2.0 Kings shock with coil over and reservoir = $2,800
Deavers Springs custom built spesifically for the Rize kit = $900
Custom Upper A arms = $1,400
4 Front, 2 rear air bump stops, front and rear limiting straps, including installation $2,600
4 38x18 Toyo tires including installation and alignment $1,200
Time and other materials used approximately $1,000
Approximately $12,900
[QUOTE=OGTerror;3861043] Hell yeah always fun to go 4 wheeling check my videos out
click on the url down here VVVV
ya those are some pretty sweet videos i have all ways enjoyed going 4 wheeling my dad, my brother and i have two rock crawlers that we like to beat on you can check pictures of them in my profile if you haven't all ready
