Ball joint replacement help
Remove wheel and brakes. Remove cap from the hub use 13mm to remove that nut. Remove tierod and upper balljoint with 21mm and the lower with a 24mm. Will have to wack the spindle a couple of times to break the balljoints and tierod free. Remove spindle from the truck and then go to work on the balljoint. Need a pair of snapring pliers to remove the retainer clip and the wack the balljoint out with a hammer(hit the outside of where the balljoint sits first) then you will need a press to get the new one in. I have my own but you can rent one from your local parts store and the reverse the steps to get it back together. Sorry if it was kinda brief I am one my phone. Just trying to give a howto over the phone on a tiny keyboard is totally different the a computer lol
I found a How To for the Ball Joints on another forum.
http://www.ford-trucks.com/article/i...ll_Joints.html
Has a nice walk through on how to replace the joints on 97-03 F150's. Should pretty much apply the same for the newer trucks.
