Needing to replace shocks soon
I want to get some aftermarket ones, If i got 4" lift shocks, would it actually lift up the truck, or do i need to get other equipment too? like the coil spring and aal stuff?
These are the ones Im looking at
http://cgi.ebay.com/ebaymotors/4-Pro...=p4506.c0.m245
So can I put Bilstein 5100's on all four corners of an 03 4x4 Supercrew that I do not want to lift? If I do, am I going to get a stiffer ride (be quiet Beavis) by running on shocks that are compressed 4 inches shorter than they would normally be at rest?
i loled
i would think that running a shock at a highly compressed state would not only result in a crappy ride but also a shorter life for the shock
you need to get the correct length shock for your application
