gauging interest on removal
i am curious to know how big of a PITA it would be to take my body lift off. i am wanting to go with a suspension lift kit. i am curious because i would like for someone to just goto a shop with me and have the shop trade it over to there truck. difficult or not.. and what would a good 6-8'' lift kit be i know alot of people talk about the RCD kit and its pros and cons with people running king coilovers which i know are pricy. all input is welcome thanks alot guys
I paid a guy i knew to take mine off i forgot how much he charged me but he left the stuff in the engine dropped and took the blocks out and other stuff that deff needed to be taken out like steering extension, gas extension it can be doen and then when i did it myself putting it back on i just did the blocks and those the other stuff
pulling it really wouldn't be that bad. all you would need are the factory body bolts. the thing is, the fan shroud was cut and modified to mount onto the engine block along w/ the fan blade. the factory set-up has the shroud mounted onto the radiator (body) and the blade on the engine (frame-mounted)
you would have to either leave those parts in, or swap to e-fans, and delete the fan shroud altogether. i will agree that ground clearance sucks with a body lift, and just 35's, and you probably do experience some level of rubbing.
the new gas lines that came w/ the kit can be cut down to stock length. the steering spacer is entirely removable.
nothing was done w/ the body lift that makes it an entirely "permanent" modification.
well i mean i dont hae any dislikes with the body lift its just that i do like to go off roading and i am just worried that with only the body lift the articulation and flexing might not be good for the truck.... who all has taken there truck off roading besides just mudding i mean were there truck actually gets flexed and stuff???
