Leveling kit help PLEASE!
CUZ...Here are the pictures. The truck will stay on the stock tires until they are worn out then I am going to get 305X65X18
Pre-Leveling and Pre-AAL
Leveling Kit only
Leveling and AAL
The add-a-leaf install would be very easy, had the two bolts that hold the leaf spring together not been stuck. I had to cut them off. On the second side, I had it finished in twenty minutes.
Leveling Kit only
Leveling and AAL
Wow, I'm showing 14.5 to 15.5 on mileage with 285/70/17's...?
Hi Outdoor FX4,
I have the same truck as you and want to put the exact same kit on. THe shop here quoted 5 hours for the work and to me it seem ridiculous. How long did it take you to do it? It sounds like the AAL was really quick, but what about the front leveling kit?
Thanks,
Fred
Thanks,
Fred
Hi Outdoor FX4,
Thanks,
Fred
Thanks,
Fred
Fred....the Font took me about 4 hours but I had to run and get a larger pitman arm puller on my bike because the truck was disassembled. If I had to do it again, I would think that it would take under 45 minutes a side with the right tools. The rear, once again I would estimate would take at most 1.5 hr. If you have any tools/skills you can install this yourself. It really was not that difficult, but you must have the right tools.
Thanks a lot. Thats what i wanted to know. Does the AS kit comes with u-bolts or you can reuse the same one?
Cheers
Cheers
