a how to for installing a leveling kit?
I just finished installing the autospring 2.5 inch leveling kit.
www.autospringscorp.com
While it came with instructions, the write up on this site was much more helpful. It is a very easy install, and this was my first "real" work on my truck besides simple maintenance. Good luck.
here is the write up that helped me out when I did mine.
https://www.f150online.com/forums/ar...ll-photos.html
the 2.5" leveling kit will put your front end prob slightly higher than your back or completely level, on my '06 itwas a tad higher than my back with my 2.5" but I wanted a little rake so I added a leaf spring to the rear. Those tire will put it up a little more but arnt really a true 33" there something like 32.7" so you could go with a 325/60-18 which is about 33.2". Or if your running stock wheels or certain aftermarket wheels you can look at 325/65-18= 34.7" but will require some trimming.
