Need sum help
Need sum help
Ok, i have a 2004 f-150 2wd drive, it has a 2.5 level spacer. i just brought the rancho quick lift part (rs999767) and the rear shocks part (rs999285) had a shop installed the front struts, they took out my 2.5 spacer n when said and done the front sat lower then the rear.. look like stock all over again, hated the look went back the next day had same shop recharge me to put front spacers back in, now my ride is so hard its worest then when ii was before i spent all this money.. i was thinking maybe cause i have the spring compress so mch thats why i getting a stiffer ride.. i dont want to take my spacer out and i dont want this to turn in a 2,500 dollar project either. so my question is if i buy a 2inch lowering spring and install in will it drop my truck 2inchs or will my ride be better??????? also have the wireless control for the air int the socks rancho (rs999705)
