Leveling kit: A-Arm hitting Coil!! How to resolve??
While driving over speed bumps or any big bumps the front suspenson extends enough to cause the upper a-arm to hit the coil on both sides. It has been this way for years and I'm tired of it.. Anyone know how to fix the problem or another kit to buy.. I have a 2.5" billet kit now..
Thank you!!
Thank you!!
Yeah, I saw that style. I wanted to see what you guys though would be a good idea. Its only rubbing a little. Just enough to wear the coating off of the drivers side spring. Your idea may take care of that. Thanks for your timely responce.
Oh, I think I'm a member under another name. It's been a while so I started over, haha.. It hasn't hurt anything yet, it just sounds like a Dodge when I hit bumps lol.. Thanks again
a leveling kit that sits ON TOP of the strut will cause a-arm to spring contact because the arms are able to droop the extra amount. A spacer that goes between the coil and the upper strut mount or Bilstein 5100 shocks will not have a-arm to coil contact because the strut will still "top out" the same as it did before it was leveled.
Well, I purchased the offset. Its the only lift that make actual sense. The bilstein ides is nice and I understand the concept. Its just that when you are adding a greater angle to the control arm it causes them to move closer to the coil either the spacer way by adding from the top or the shock way by adding lenght up from under the coil. In my mind they should both hit the coil. Auto Sping is a good company and an easy fix. I will probably only own the truck for another 2 years anyway, max. Thanks for the input!!
