suspension lift question(97-03)
assuming I get the leaf springs and shocks with the lift kit what all does the lift kit leave out of the front suspension, I ask because I need to do a complete overhaul on my front suspension and I am wondering if I get a suspension lift what would be left for me to replace
ie inner outer tie rods/ball joints
None of that will be included with a lift. Ball joints(upper or lower), any bushings, tie rod ends, pitman arm, idler arm, nothing!! Only thing component wise that will be ncluded that I can remeber is the sway bar end links, and that's only cause they're required for the lift. But, not totally necessary for a lift. Only necessary if they're worn. The bigger/heavier wheels and tires wreak more havoc on components than the lift does.
