Rancho 4-6inch Lift User Chime In
OK well im trying to sell a set of bilstein shocks for up front. Now the shocks that i have were originally made for your style lifts 4-6inch. But was wondering what kinda front set up you guys have? Did they come with different strut assembly or is it the factory strut system and like a spacer or something i dont know. Trying to figure out if these will work with the Procomp, skyjacker or any 6inch lift out there.
Thanks,
Josh
Thanks,
Josh
Ok so these bilstein shocks will work with a factory coil/strut assembly. Bc these shocks were originally made for your 4inch rancho lift. But sense they use the factory strut then you can use the other setting to acheive 6inches of lift as well? Make any sense ?
Yeah that's what I thinking but the member jordan on here wants them but has a procomp lift and is looking to get rid of his 6inch spacer. So just replacing the bilsteins with the other shocks should work bc these have the longer body valve. Just needs to put it at the 6inch lift setting and should be good to go
