3" bl and 37's
3" bl and 37's
I've been looking at getting an 04+ f150 4x4, and I know that with a leveling kit you can fit 35's on these, but ive been wondering if you fit 37's with a 3" body lift? IT would make sense that you could, but I havent seen it done. IF you can does anyone have any pictures of it?
You can't and even if you could those tires would be stuffed in the wells.
I did'nt think you could because I've never seen it or heard about it, but I just don't understand why it wouldnt work. If you can fit 35's with a leveling kit, why not add a 3" bl and put 37's? I don't understand how that wouldnt work, so if someone could explain that wouldbe great.
I don't see why it wouldn't work. It worked on my 2002 king ranch. I will post up some pics later. I ran 37x12.5 all terrains on my stock rims with aftermarket torsion keys and a 3" body for about 2 years. They only rubbed a little on the frame at full turn, but i knew how far i could turn before they did and just didn't crank the wheel full turn. If you are trying to offroad it regularly then i wouldn't go with the 37's. But when i had that setup the truck was a street queen cause it was my first vehicle that cost me over $20,000 and i wasn't about to mess it up.
I know a member on here, jnic24 I think is his name, ran a 37 with just a 3" level and 3" bl with no rubbing but the tire wasn't a true 37. They actually measured 36.4". 37's are NOT bigger than the wheel well. A member on here has a picture in his album of his 38's stuffed completely into his wheel well. They actually measure 37.75" but appear to not even touch the fender.
