Questions About leveling Kits...
I purchased a leveling kit for my 2005 F150 Crew, on the weeknd new off someone who did not end up wanting to install it.
I measured the spacer and its 1.5" tall, does this mean that it is a 1.5" in lift?
whats the max I can go on the front with a spacer? 3"???
The leveling kit itself will not be the same height as you may think. I'm pretty sure you got the 2inch spacer. Mine measured out to about the same I don't remember but when it was installed it acheived the 2inches as I wanted. So don't freak out thinking its not going to level your truck bc of the actual height of the leveling kit.
what they do is rotate the strut 180 degrees and that gives you the additional lift. mine were 1 5/8 thick and the added twist on the struts gives me 2.5".
anything from 1 1/2 to 1 5/8 gives you about 2.5 depending on brand of level, 1 7/8 to 2 gives you 3 inch of lift. like others have said, 3" is too much. dont go over 2.5" max!
