Questions
Questions
tried searching couldnt find answers so here you go!
1)i have a 2004 single cab(although i have that extra space in the back, i forgot what this cab was called) but anyways
i read somewhere that 2004's need a 2.5" in front to level it out. is this true?
2) if that is true, then when i add my 3" PA body lift will it end up being around
5.5" inches lift?
3)when i do lift everything will i need new shocks? longer ones etc..
i plan on getting new ones anyways so any info would be great.
5.5" inches lift?
1.Extended cab?
2. I'm not too sure but a 2inch leveled out my 05. Yes its true you will have 5.5 inches of lift.
3. No need for longer shocks bc the spacr sit on top of your strut assembly and body lift is lifting the body up off the frame.
But another option if you want new shocks look into the adjustable bilsteins. They can lift you up to 2 inches of lift up front as well as the better ride quality.
But now that i have had my 2.5 on for a while it has settled a little and the back is just about 1/2in higher then the front but it is not enough to notice
