lift & leveling my 03 f-150 4x4
Holy crap, people like wasting money on anything these days. If the package says it ok then it must be perfect. You need to get a book and learn how torsion based suspension works before throwing 200+ dollars away. the suspension works off of preload, the more preload the higher the truck will sit, by cranking stock torsion keys you are adding preload, aftermarket reindexed keys do the same thing except they allow for more preload, which is bad. You don't want to go any more than 1.5-2" on torsion keys alone, you can easily and safely get this by cranking your stock keys. if you actually think your gonna get 4" of lift by cranking aftermarket reindexed keys you are a fool, it will not be Driveable, even with 2.5-3" via torsion key lift you would not be able to align the frontend.
