In need of HELP, going Rancho 4"
I just measured my wheel wells and the fronts measured 43.75" and the rears came in at 44". So only 1/4" of rake, I can't even see it.
I believe that since it is all taken apart, you should upgrade with quality components: Replace both upper control arms and lower ball joints. I like Moog products so once you replace the uca, the ball joints only can be replaced when needed, and both bj's come with zerk fittings so they can be re-greased. Many here have reported premature bj wear and I think it is due lack of grease fittings. The Moog stuff is heavy duty and not very expensive when replacing both sets of uca's/bj's.
When installing my lift, swapping in the uca's and lower bj's added about 1.5 hours to the install.
BTW, if going with huge tires or extreme off-roading, consider the Camburg uca's...those things are awesome!
You can see my Moog uca/bj in this pic...it is slightly beefier than the OEM uca.
FYI... most lifts specify a rim with a 4.5" backspacing. On a 9" wide rim the offset would be -12mm. Here is a pic of a 20x9 KMC Hoss rim with 4.53" BS -12mm offset and a 12.5" wide tire... to give you an idea of how much tire will stick out. This is on an 09 F150 with just a 2.5" level. Some trimming was needed.
***I am by no means saying a 5.5" BS will not work... I really do not know.
As for adding a level, i dont know why you would want to on top of a lift other than to just add a little more height. If this is the case, I really would just suggest to go to a 6" lift (IMO, BDS has the best 6" on the market... there is not compromise for a no questions asked warranty). If you are nose high or nose low, I would adjust the rake with the rear. It is much cheaper and easier to alter the rear (AAL, Blocks or shackles) than it is to add a front level (dont forget everytime you alter the front, the geometry changes and an alignment MUST be done).
Just my 2cents.
Just my 2cents.
