Need rear lift info...
I own a 2004 F150 i have a 6" procomp stage 1 and recently added front Bilstein 5100 adjustable shocks and rear 5125 shocks measured long enough for when I lift the rear. The deal is i ordered the 3 height adj. front shock from Top gun customz and they sent me the right shock but it only had 2 settings and was designed for RCD suspension so I set it on the top notch. Which im pretty sure is 2", but not quite sure. I cant seem to get a straight answer from anyone on the exact height...Anyway point being the back sags now and has anyone else had this ordeal and can tell me if a 1 1/2" AAL from autospring or the 2" Rize AAL will work to level it? Thanks.
