Rancho lift questions
I am looking to get the Rancho 4" kit for my 06 Screw 4x4. I was wondering what shocks you guys would recommend. I dont do any off roading with the truck. I know they have a special going, and if you buy the lift and 4 RS5000 shocks you get a $400 rebate and with the RS9000xl you get a $500 rebate. Are the rancho shocks any good or are the Bilsteins better. Also I was looking to keep the stock 20'S for now, so what tire size can I run with those and the 4" lift without doing ang hacking of the inner fenders. Last, where does anyone recommend getting the lift online for the best price. Thanks for any help. Mark
I'm running the RS9000 adjustable shocks and I think they're great. Also running the stock 20's with 35x12.5 Mickey Thompson ATZ's. They fill the wheel wells perfectly and I didn't have to cut anything. At full lock the side biters barely touch the lower control arms, but it is only if I have it at full lock and keep the pressure on it while turning, it's so minimal I can't consider it an issue. It's a great lift kit. Fit and finish are excellent, you won't be disappointed!
I've had both Bilsteins (with 2" level) and now the R9000 adjustables with my lift and both are excellent shocks. To be honest, I give the edge to the Rancho shocks with adjustable valving as they allow you to better tune your ride especially if you intend to carry a load or tow, etc. But as mentioned, you cannot go wrong either way.
See a similar thread: https://www.f150online.com/forums/su...ancho-4-a.html
Someone correct me if I am wrong, but your OEM rims are only 8" wide with close to 6" of backspace. Therefore you should have no issues with the tire rubbing at full lock, as long as you stick with a 35x12.5 tire.
Hope this helps!
Pretty close, the OEM 20's are 8.5" wide. Just want to clarify that in case the OP is looking for tires within the approved width range.
That would be the same combo I'm running... As StoveTop said you won't have any issues.
