Suspension Lift Help
Hey guys im new to the forum, i have a 2006 Ford F150 STX. I would like to do a 3 inch lift and 33in tires. I was thinking maybe a 3in leveling kit and a 3 in add a leaf for the rear or rear lift blocks. Please let me know what you think or what you would recomend. I also dont want to spend 1k on a lift so please help me out
Option 2: 2.5" levelling kit up front, may or may not make your truck sit "bulldog" (slightly higher in the front), at which point you could do an AAL, blocks or air bags in the rear.
Option 3: Some shock manufacturers make shocks with the capability of providing up to a 2" lift up front. These are pricey but if you need new shocks anyway, I would recommend Bilsteins.
The consensus around here is to not exceed 2.5" with a levelling kit.
A popular brand of levelling kit is Autospring. They also make a 3" rear block (which replaces yout factory 1 5/8" block) and an AAL. If you want some adjustability with your rear end, Firestone Ride Rite air bags are an option ($250).
2.5" front
http://cgi.ebay.com/ebaymotors/Auto-...Q5fAccessories
1.5" AAL
http://cgi.ebay.com/ebaymotors/1-1-2...Q5fAccessories
1.5" rear block (actually 3" tall to replace the factory plus add lift)
http://cgi.ebay.com/ebaymotors/2004-...Q5fAccessories
Bilstein shocks (with 2" leveling option)
http://cgi.ebay.com/ebaymotors/2-Bil...item5ad88d563e
This is all assuming you have a 4wd.
I, and many others on this site, run a 2.5" Autospring in the front, the Autospring blocks in the rear with 35x12.50x18's on the factory wheels. I have since swapped out the blocks for the Firestone airbags.
Check this link out for some pics
https://www.f150online.com/forums/20...s-leveled.html
Both the 2.5" front and 3" rear block are bolt on so no other parts are needed for installation. Now, since your truck is 4 years old, you may find some parts along the way that you "choose to replace", but it won't likely be a "have to replace". Now, go lift your truck!
Thanks for the help! One more question would having the 2.5 front and 3" back give me to much front dive since it already has front dive. I want to keep the front lower just not to much to a point to where it looks weird. So my question is is the .5" realy going to make my truck have to much front dive if that makes any sense?
Option 1: 2.0" levelling kit up front, nothing in the rear.
2.5" front
1.5" AAL
2.5" front
1.5" AAL
So im actualy considering getting this lift
http://www.summitracing.com/parts/SJ...n/?prefilter=1
i realy want a 3 inch lift
let me know if you think this is a good kit or if i should get another kit or add more parts to this kit.
Thanks again for all the help
I wouldn't recommend the Skyjacker 3 inch lift. As the others have told you, 3 inches is just too much lift without dropdown brackets. Also, the most common high wear items are actually you ball joints, not the CV joints. I've read more post about premature ball joint wear than CV joints. I'd suggest going with a 2.5 inch Autospring lift and a taller lift block out back.
