leveling kit?
leveling kit?
I have a question that is probably a dumb one, but I read these forums everyday and know there is alot of knowledge here to help me out.
I have a stock '06 SC Lariat with 18" wheels and the original tires. I hate the stance of my truck. It looks like an old man's truck. I had an '01 SC Lariat and the stance was much better. Eventually I'll be putting factory 20's with with a regular factory sized tire on my '06.
Question #1--What's the difference between my '01 and my '06 Lariat's stance?
Q #2--I see that alot of guys put leveling kits on their trucks. I this what I need and if so, what size? It seems like the front end sits a little lower that the rear.
I'm not into jacking my truck up so I need a ladder to get into it. I just want it to look like a truck and not a grocery getter.
Thanks for the help.
Question 1: Assuming both are 4wheel drive, 01 has torsion bars and your 06 has coilovers. Thats the main difference, honestly both of them have similar stances. There is a good chance if you bought your 01 used the previous owner cranked the torsion bars so it sat higher.
Question 2: 2" or 2.5" Autospring or Hell Bent steel leveling kit will do you good.
Welcome to the site.
1 thing... Its best to search for what you're looking for (just in case you didn't know there was a search), however sometimes I will admit its hard to find exactly what you're looking for sometimes...
2. Its best to start a new thread as opposed to "hijacking" a thread that's more or less unrelated
3. To answer your question. You can fit 315s with a 2.5" level kit. Search for "PawPaw." He has a similar setup, except with aftermarket rims with stock dimensions tho... And just FYI, for the most part, anything you could do afa tires/wheels with the '04-'08 model you can pretty much do the same with for the new models... There is very little difference in that aspect. You can even run the same wheels - bolt pattern is 6 on 135 for '04-
Hope that helped ya out! and again, welcome to the site!
