Dropping the rear end
I bought the Ground Force kit at a local truck supension shop. Installed it was $142.
You can buy the kit online for about $90. Just google Ground Force. If you have a floor jack and stands, it is not too hard to install. If you don't want to do it yourself, call around to some shops and see if they have the kit. The shop here had it in stock. If they don't, I bet they would get one.
Will these fit? It doesn't say if it'll fit a 07
http://www.amazon.com/dp/B000CMDGXY/...Y&linkCode=asn
The shackles are the same for 04-09. They're very easy to install, but like what was said earlier, make sure you have pinion shims installed also to avoid vibration.
http://www.summitracing.com/parts/SPS-86255
Not necessarily. They should, but some shops short cut. Some kits are shackles only, wedges have to be bought separately. They were in my kit, but the installation guy tried to short cut it and not install the wedges. He test drove it and said it did not vibrate. I made him go back and put them in. Vibrate or not, the pinion angle had still been changed and I wanted it back to correct angle.
Alrighty well i'll make sure he install's those. Thanks for the heads up. Well just called to double check that it comes with pinion shims and it didn't they're an extra $60 bucks =( so i'm gonna call around and see what i can find. updates later
