Official Lowered 4x4 thread
Old 07-30-2012, 10:45 PM
coobies5's Avatar
2002 crf450r
  #332
Old 07-31-2012, 07:23 PM
06yz250f's Avatar
Originally Posted by McDuff
5. I see some members from the Dallas/North Tx area, anybody know a good shop to take it to?
Install 2wd front coil assemblies and remove rear block and add a drop shackle. Should drop you ~2/3.5"
That's my suggestion, not sure what the lowered guys think tho
  #333
Old 08-03-2012, 01:27 PM
McDuff's Avatar
Thanks 06, am working with a lowered guy and that was his recommends too. slowly working the details.
  #334
Old 08-06-2012, 06:49 PM
vampfreaks's Avatar
I have an 01 F150 Lariat S-Crew 4x4 and i want to lower it as much as possible without rubbing i am running a set of Harley Replica 22"s they are 22x9 and i am running a set of 305/40/22 for my tires if anyone can help me that would be appreciated
  #335
Old 08-06-2012, 07:01 PM
Goleta1234's Avatar
I am thinking about removing the rear blocks on my new 2012 4X4 Screw, but I was wondering where is the best place to get shorter u-bolts.
Thanks!
  #336
Old 08-06-2012, 08:39 PM
coobies5's Avatar
Aftermarket lowering torsion keys or chevy 1/2 ton 4x4 keys 99-07
remove lift block, 2wd u-bolts, shackles + hangers or leafs
not too sure about if you will rub or not, if it does all those suspension components are adjustable to lift it up if it does rub.
Thanks!
auto parts store or get some off of a 2wd from a junkyard or another member
  #337
Old 08-11-2012, 03:20 AM
Andy Benoit's Avatar
hmmmmm... has anyone done a 3" drop on a 4x4 with the higher and wider fenders to fit large (35") tires? kinda like the way a Hummer is (the real ones not the H2 H3's) LOW but large tires?
  #338
Old 08-11-2012, 10:48 AM
coobies5's Avatar
That just sounds like rubbing issues already.....
  #339
Old 08-11-2012, 11:00 AM
five0merc's Avatar
Agree with coobie on this one. I had 35's on stock height on my 97. Just cranked the torsion bars a little and had rub at full lock. If you find a way to do it awesome man. Would look pretty neat I think.
  #340
Old 08-11-2012, 12:18 PM
coobies5's Avatar
I think there was a thread on here somewhere about vehicles running offroad tires on lowered trucks
  #341
Old 08-11-2012, 03:11 PM
fine_style150's Avatar
Haven't seen it, but if your planning on fenders to accomodate the 35s it is very well possible. doubt itll work with a 3" drop though
  #342
Old 08-23-2012, 01:55 AM
mmalcolm24's Avatar
My first post here. We've got a '12 F-150 SuperCrew 4x4 Ecoboost Platinum, I am interested in lowering it a touch. I am in a wheelchair from a motorcycle wreck, my DD now is a ramped modified minivan, so technically it's my wifes truck. We got it to tow our bass boat, and for fun of course.
I have a chairlift system in it to take me from floorboard to seat level, but the seat is about 2-3" too high for an easy transfer, so I would like to fix that. It will also be easier on my wife, and we both like the look of a lowered leveled truck.
So, after reading all 22 pages of this thread plus many others I have some thoughts and questions.
I want a basic lowering that won't impact ride or towing, so prob 2/4; 3/5???
1. I can't find any kits being available for the 2012 models, are 12's the same as 11's?
2. So I can get a basic 2" drop all around by removing the rear block and using 2wd shocks all around, correct?
3. I am still confused on what it takes to get another inch or so in back to level it out. I think I want a little rake for towing purpose, even though tongue weight isn't that much on our boat. decisions, decisions...
4. What parts of the warranty will be voided by doing this?
Thanks.
My Girlfriends Dad is also in a wheelchair and he has an 07 FX4 that is lowered 2/4. He used 2" drop coils out front and either Eibach or Roush leafs and removed the rear block. The truck rides great still and can still tow a trailer no problem as I used it to tow a enclosed trailer about 1000 miles to his new home for him when they moved.
As for kits everything from 04-12 will work as nothing major has changed on the F150s there are little changes but dont affect the lowering kits.
  #343
Old 08-23-2012, 10:38 AM
McDuff's Avatar
Mmalcom, thanks for the input, sounds similar to what I am going to do. I only have a 1" diff from front to back so I am doing a 2/3 by replacing 4 shocks with stock 2wd models, removing the block, and adding a 1" Belltech drop shackle.
Glad to know the ride is still great after doing it, definitely don't want to mess that up. An I think I may still have ~0.25" rake when done so pulling the boat should not sag at all. I'll put pics up when done, but it will be a few weeks.
Thanks again.
  #344
Old 08-25-2012, 07:11 PM
fstfrd's Avatar
I recently purchased a 2012 F150 4x4 STX regular cab and have been researching lowering it. I traded in a lowered 2004 Lightning so the height of the truck is not to my liking. I've noticed two kits: Belltech 965SP and DJM 3209-3/5. Both advertise 3/5 drops. Anyone used these kits? Recommend other kits instead?
  #345
Old 08-26-2012, 12:29 PM
mmalcolm24's Avatar
I just finished lowering a few 4x4 the last month I found if I lowered the back 4" they sat closer to level and if it was 5" the back would sit lower then the front.
Quick Reply: Official Lowered 4x4 thread
