torsion bar problem help?
No mine are fine and where they should be. Maybe push them tom the rear a bit from the c-arm. and as far as a fix, well I haven't been able to try anything yetcause I've been too busy with other thibngs. I will prob get to it this week and will let ya know. If you figure something out before me hit me up.
same thing happened to me a while back, every time i would drive slow i would hear the squeak, i ended up replacing my Idler arms and sway bar links, the noise quit. I talked to a friend of mine that is the charlie Daniels of a torque wrench, and he said after 80,000-120,000 they start to wear out. good luck i hope this helps
Ford fan, my bad man I guess I misread your post. Yes my t-bars actually rubbed this cross member/skid plate (if its what I think your talking about). I actually had to move it forward and have the front bolts hold it at the rear mounting slots. If this makes any sense. Then the t-bars fit and I have about 1/2 inch from the exhaust pipe that goes across with no clearance issues at all.
Yeah dude Im on it on Thursday along with my brake lines. I got some marine graese i'm going to put on my keys to see if this works. Did you have to get longer brake lines or are your stock ones good? If you need some I'll send you the company I found mine at and they were the cheapest, even cheaper than gettin em made here locally in my town. Let me know.
great man that would be sweet. and no i havent had to change them. but the are close to being tight. its not of my list of needs but go ahead and sent that company. and i took the truck mudding today and the road, where my bars squeaked, i didnt hear it. im not sure if my truck was covering up the noise or what but i think mud has helped a little haha
